Freezerman
OK so I found a 69 318 for $280 that I am told is bored to 060 over with 3500 miles on the rebuild. It has been sitting in a garage for 2years.
I pulled the valve cover and found it has 894 340 heads on it! It also has the timing marks on the passenger side of the cover.
Questions.
Can I use the water pump with the inlet on the passenger side still with the passenger side timing mark cover?
The engine turns over nice by hand, if I pull the pan and it looks good should I be able to run it?
Assuming the info I got on the engine is correct, has a Crane 272 cam, will the 340 heads be good or should I sell them and get different heads?(unknown pistons)
It also came with a Torker 340 manifold, I also have a Performer manifold, would either of those be good or should I find something else?
Thanks.
Questions.
Thanks.
