NEW radiator
DUSTPAN340
Cedar Rapids ,IA
Just got my new radiator for my 1970 Duster (DUSTPAN)...The tig welds are AMAZING...the shroud is a work of art as is the rest of the radiator...the shine on the top part of it I can comb my hair in the reflection...the part will deffinitly shine up my engine bay with the new motor...it has 1.25 tubes running in it to help it cool for the added HP i'm putting under the hood....I had it built without the trans tubes in it..since I'm running a 4 speed...Thanks for looking...Wayne
:burnout:
Have the same radiator in my 70. Scott is great to deaal with although mine doesnt shine like that one. I have had mine for 3 years now. Wizard cooling is a great company.
your right..Scott is great...I worked with Tom and Dave as well...Tom did some of the designing work for me.......now I have more to wax and shine up....:banghead:
I got my radiator from them today. Unfortunately it doesn't fit. I have contacted Tom and compared their numbers to my original radiator. They are going to build mine to correct a couple of design issues. So far they have been very good to work with.
Most of the issues seem to be the bottom tank and shroud brackets.
Great radiator. I purchased a Wizzard Cooling radiator for my 68 Barracuda last summer. The radiator I purchased was the two row with 1.25 in tubes and the shroud. The shroud is nothing less than a work of art. The system keeps my 416 stroker cool in 90 heat. The radiator and shroud were not cheap but the radiator, shroud and service were first rate.
Yeah, be careful on the part numbers. The first one they sent to me which they listed for a 68 Barracuda didn't fit. The bottom tank was too big and hit the bottom. I luckily saw an old photo from their old site that had a different part number. I called and they sent me the drawings and measurement for that radiator. It seems that those numbers were all correct except for the lower hose connector being a 1 3/4 instead of the stock 1 1/2 inch. They are currently building that radiator for my car and sent a call tag for the wrong one. Hopefully this one will be right.
