[SOLD] NEW SB Mellings valve springs set of 16
Dmopower
I have a new set of Melling Valve springs. I bought these this year and could not use as my adj rocker arms hit them. They have been installed and the rockers were never bolted all the way down as the rockers rubbed. 60.00 plus shipping from Des Moines, Iowa.
Do you have any specs on them. Open, closed pressure etc. Are they basically a 340 stock replacement?
Yes these are 340 replacement plus a little more the way I understand it.
Type: Dual Spring, Single with Damper. Installed Height and Pressure: 1.650'' @ 91-101 lbs. /in. Open Height and Pressure: 1.22'' @ 231-245 lbs./in. O.D. of Outer Spring: 1.494''. I.D. of Outer Spring: 1.080''I.D. Coil Bind Height: 1.100''. Material: Chrome Silicon Wire Size: 0.207''. Damper Included: Yes
