[SOLD] New Strange S60 with Brakes - $1400
jdakota
Winterport, ME
Brand New Strange S60 Rear End with Brakes - $1400
This is a new Strange S60 rear end that’s never been in a car. It’s built with a hardened yoke, hardened axles and 5/8” lug shanks. In short, it’s made not to fail under high hp.
I bought this intending to make my car an invincible Drag strip only car, but have since changed my mind and am going to build a street car instead. So, I don’t need this S60 anymore and am going to sell it. This package sells for over $2000 regularly, so here’s a chance to save some money if this is what you’re looking for.
The Specs are listed below:
Bolt Pattern: 5 on 4 ½
Length - Hub [mounting surface] to hub: 49 1/8
Axle to Axle width: 48.875
Standard Mopar pinion offset: 1.188 inches to passenger side
Early Big Ford housing ends
40 Spline hardened axles
Chrome Moly Pinion Yoke
5/8 x 3.188” Wheel stud kit
Spool Dana 60 40 spline
4.10 gears
Ultimate Aluminum Cover
Strange 4 piston Brakes (11 ½ inch rotors) B1708WC
My preference is to sell this face to face with whoever the buyer may be. I really don’t want to ship. Since I live in Las Vegas, I will be at MATS in April and also attending the Mopar show in Van Nuys, CA the following weekend. I’m also planning a Seattle trip and a trip to the Dakotas soon. So basically, anywhere western USA.
PM if interested. Thanks.
what was this car this was built for. A-body or B-body. That rear end would look good in my 64 Dodge 330. Do you have a length of the housing flange to flange. I am interested.
did you get a chance to measure the housing flange to flange or do you know the measurement center to center of the spring pads on an A-body when they are moved in.
