New to this forum!! Steering problem that I need advice on
Rpilejr
New Member
Central city
1974 lower steering column bearing fix?!! Please help 814-279-9471
Trying to find a fix for the lower bearing in the steering column for a 74 hang ten has anyone ever ran into this that can give me any advice on a fix for this all help is appreciated
well, lets get some better info - what exactly is wrong? you got noises - parts falling off - other - ???
GO INTO THE SEARCH AND SEARCH FOR STEERING COLUM, IF YOU CANNOT FIND AN ANSWER POST THE PROBLEM HERE. THE COUPLERS ARE NOTORIOUS FOR FALLING APART. Welcome and just ask! Must be a going back to work hiccup today!
Thank you for your support after I joined and made the post I went and searched and found a solution to my problems ! I needed the lower column bearing
