Crazy4408pac
N. Michigan
Have some pix and some questions. Below are some pix of the welds on the new floor pan, in my 72 Swinger. Not the best but ok for my first time. I can stick weld and oxy braze, quit well. Learned many years ago in high school. This is my first try at wire. Used a cheapo Chicago Electric 90AMP flux wire and .030" wire.
My next thing will be the (pardon me if I don't use the correct terms), lips on the fenders. I plan on buying new inner fenders. Too bad they don't re-pop fenders.
Here's a question: Should I cut a piece the full length or use a couple of pieces then tack them together after welding them to the fender?
Have 73 Charger with a 440/727/489, that I will be pulling out and putting in the Dart. Will be using an Alter-K for that.
I'm going to try and get the Dart done as far as body work and the Alter-K before I pull the Charger apart. I'll be using the drive shaft and the pumpkin from the Charger, in the Dart. Have a 70 B-Body 8 3/4 I'll be using. Just have to move the perches in 1/2"
