ngk ur5
Slantsix64
SSG
i have a 1979 slant six cast crank i will be using ngkur5 do i remove the washers? thanks in advance
hey, ya they dont have em thats why i was wondering if there a need to remove them
Do yourself a favor and install the factory Champion spark plugs. The ignition system was designed with them and works the best. Cheap too.
I thought the plugs for heads without the plug tubes were tapered seat plugs and therefore didn't use washers. I can't remember what kind of plugs I used to get for my 79 Volare wagon slant 6.
-Matt
If they tapered seat plugs, they don't come with any washers. Nothing to remove. Are you certain you have the correct plugs for your year head?
