Nice stock throttle cable bracket that works with aftermarket manifolds
oldkimmer heres the one I got off a van with a Rochester Q jet carb. Its lower in height than the other one I am using with my performer RPM. I was wondering if I could use the kickdown rod and linkages off this van on my sons 69 A body with a 42RH trans instead of a cable setup.
I was also thinking of going back and getting its 4bbl intake manifold as well. Wondering how well this would work with an adaptor for an eddy 600 squarebore carb on a 318.
. Sorry no it won’t work on an A body. Those came on B and E bodies first with the 340. Then on to the other body styles. Maybe if u get the down rod off of a truck as they have less room than the B&E bodies between the engine and the firewall. I haven’t tried an F body rod aE I never had 1 to try. Hope this helps. Kim
This was the alternate setup I was planning on with a TV cable and lever setup off a ram van. A steel 4bbl intake off a ram van for about $25 if I wrench it off sounds like a decent deal though I think
