1970 engine with 68 style cast iron water pump going in 68 Barracuda. Having issue with heater core pluming. The nipple on the 70 intake manifold is too small for heater hose. Smaller than 3/8 but larger than 1/8 NPT. Do you guys drill and tap it larger for 3/8 nipple? What's the cure for this.
Thermostat spacer with EFI sensor port | AR Engineering
