340Dart Obsessive Dart Disorder FABO Gold Member Joined Jan 8, 2005 Messages 770 Reaction score 219 Location Mount Morris, New York Feb 14, 2022 #1 I'm running a power shot 125 on my 340 4 speed. I normaly shift at 6500. When using the nitrous do you shift at the same rpm's?
roccodart440 Well-Known Member Joined Apr 19, 2010 Messages 6,801 Reaction score 3,578 Feb 15, 2022 #2 340Dart said: I'm running a power shot 125 on my 340 4 speed. I normaly shift at 6500. When using the nitrous do you shift at the same rpm's? Click to expand... Without a dyno sheet, no one can answer that. You'll need to do a test to get that answer. Make runs with your shift point set at 200RPM increments. I would start below 6,500, say 6,200. Run it, then up it 200RPM. Did the ET drop? yes, up it again. If not, go in the other direction. Last edited: Feb 15, 2022
