mitch340Duster
1970 Duster fresh restoration so no history available. I rebuilt the trans. I've done 2 or 3 before and never had a problem. New Hughes converter. Low is fine, Reverse is fine, 1-2 shift is nice, but no shift into 3rd. Linkage is adjusted correctly. I went through the valve body completely again. Found that for the pressure relief I put the spring atop the ball instead of the ball on the spring. Figured I'd be all-set. No change.
With the wheels off the ground I revved it pretty good but still no 2-3 shift. adjusted throttle pressure some and still no change.
For road test I disconnected the throttle pressure since if I remember right it should still shift manually without it. Same thing, nice crisp 1-2 shift but no 2-3.
Car runs bad and is dangerous to drive now because of steering box adjustment and no front end alignment so at this time I cannot lean into it on the road but as I said with the wheels off the ground it still won't shift even at at rpm's of 3,000-ish.
Thanks for the help. This was a difficult topic to get good search results on.
