No fuel to carb
I rerouted the fuel line today, because it had a spot that went up a little higher than the tank, and blew back through the line with not resistance. Ran a line into a can and it pumped gas to the carb no problem. Hooked the line to the tank back up and the carb being filled kept it running long enough to pull gas from the tank. Now I just need to recharge the battery and get the idle set correctly. And change clothes because I was covered in gas and may have caught on fire for a little bit... oops. Thank you everyone for your advice.
Glad to hear your problems fixed !!
Be interesting to see if the fuel injection works as it is a worthwhile upgrade.
