as the title reads no lights, nothing to be had from the head, turn, brake, etc.... on my 71 duster
I've been finding all kinds of wierdness this weekend as I endeavor to install some new autometer gauges
after getting home from the transmission shop on Wednesday my friend, who was on point duty on the way back, told me that the brake lights weren't working, but the turn signals were fine
i figured i would look into this after getting the new gauges in
well the new gauges are in, they seem to work
i get in the car this morning to start working on the brake lights and decide to check all the other lights and nothing... not a thing
all the unusual wiring is back in its place, the only thing not connected right now is the nss, and I don't seem to be having any power going to any of the lights
the only things working are the non factory items, gauges, stereo, fuel pump, ignition, any ideas where to start?
items using the factory wiring, lights, wipers, horn are all dead, I've checked the fuse block - even though I can't find a reference to headlights on the diagram for it, those are all good, even got a new light switch
there are some wires leftover from the original wiring connector on the gauge cluster, which are no longer conencted to anything, but I'm not sure why or how they would affect what remains:
Fuel gauge - original tank is missing, using a fuel cell with a sending unit now
Oil warning lamp (feed), Oil warning light (send) - using the oil pressure gauge from the autometer kit now
Temp. Gauge (send) - using the autometer gauge/sender
12 Volt limiter (feed)
the only things that worked on the old cluster were the parking brake light and the ammeter, I've double checked the factory harness and it all seems to be fine
