Dorian
dorian
ghdgjh
also make sure the calibers are installed on the correct side of the vehicle (if applicable). Years ago when I was working on cars professionally, they towed in a K car that another shop (a MOPAR dealer) had rebuilt the brake calibers and could not get any brake pedal.
Turns out they had installed the calibers on the opposite sides of the vehicle (left on the right and vice-versa). this resulted in the caliber bleeders being on the bottom (instead of the top) of each caliber. No way to bleed the air out. All I did was switch the calibers, bleed the brakes and it was good to go!!
This is not a typical thing that happens, but if someone is not careful when they remove and replace the calibers: IT CAN , and it can drive you crazy trying to figure out what is wrong with the car!
Bob
