Although I no longer have that fuse box, it seems to be correct.View attachment 1714959957 By the way My fuse box upon inspection is not complete lol I'm missing the last fuse being hooked up as seen in pic plus on other side the fuse is missing bottom metal clip
So I connected them together and I had cabin power. I had headlights tai lights and windshield wipers. When I try and start it it clunks once and I lose the cabin power I had
I tried it and same thing happens as when I'm starting it with the key...I have power in cabin like my headlights are on...I try jumping starter relay and it clunks once and I lose the power (headlights turn off)Keep them connected together and try jumping the starter relay with the ignition on and see if it will fire up...
I wiggled and tightened the 2 on the main stud of relay and also waited some time. Dunno if it was the waiting or tightening
What happens when it clunks and you loose power?
Stays off and never came back?
Seems to come back on randomly by itself?
Is there anything you do to make it come back on?
What you are describing sounds like a loose batty cable, or along those lines. (crappy connection)
Measure the voltage on your battery. Then turn on the lights. What happened to the voltage? Did it drop a volt or so, or did it drop down over 3 volts or lower? You can not measure a battery correctly with a common volt meter. If each and every cell in the battery is open you will still read 12 volts. The reading will only be accurate with a load on the battery. Although the lights are not a huge load, it is still enough to give you an indication if the batt is good or not
One other question is how do I turn my emergency flashers off? they are on and my interior is all out or missing so I have no idea how to turn em off. And ive never been in an other dart to know lol
