Rockerdude Rock n' Roll and A-bodies FABO Gold Member Joined Aug 10, 2007 Messages 2,497 Reaction score 167 Location Arizona Dec 3, 2011 #1 Hey guys, I got everything on the 318 in the wagon ready to fire today for the first time and its getting fuel but no spark. My ignition setup is a MSD 5c module, electronic dist., mopar chrome coil, stock balast. Anything I should check?
1 1wild&crazyguy Banned Joined Jul 11, 2009 Messages 7,751 Reaction score 237 Location Surrounded by mopar Dec 3, 2011 #2 check if the distributor is stabbed right, that is if it was removed recently and reinstalled. u can also jump the ballast resistor real quick to rule out a bad ballast/no power to coil.
duster731 young gun Joined Mar 30, 2010 Messages 1,495 Reaction score 65 Location Venus Texas Dec 4, 2011 #3 Yup same situation happened on my buddies belvy he eventually replaced coil and after a day or to no spark again then replaced dist and is fine now
Rockerdude Rock n' Roll and A-bodies FABO Gold Member Joined Aug 10, 2007 Messages 2,497 Reaction score 167 Location Arizona Dec 4, 2011 #4 I know the dist works, it came off a running car. How would I jump the ballast?
goldduster318 Overzealous Car Modifier Joined Aug 25, 2007 Messages 1,972 Reaction score 679 Location Lake Orion, MI Dec 4, 2011 #5 If the ballast was bad, you'd still have spark in "start", just not in "run". I'm betting there's a wiring problem...check the ignition box for power and make sure you have continuity on your wiring.
duster731 young gun Joined Mar 30, 2010 Messages 1,495 Reaction score 65 Location Venus Texas Dec 4, 2011 #6 Well the dist on the belvy worked too but then it finally went out... Take the ballast of off of the firewall and check the condition of the connections in the plastic.... Have someone ground the coil wire and see if there is spark if not try looking at the connection in the bulk head..
Rockerdude Rock n' Roll and A-bodies FABO Gold Member Joined Aug 10, 2007 Messages 2,497 Reaction score 167 Location Arizona Dec 4, 2011 #7 Thanks. Is anyone familiar with the MSD 5c box?
Rockerdude Rock n' Roll and A-bodies FABO Gold Member Joined Aug 10, 2007 Messages 2,497 Reaction score 167 Location Arizona Dec 4, 2011 #8 I'll take that as a no?
