340 8BBL
i have no spark when cranking,and no power to the coil.but if i leave the key in the on position i have power to the coil and my accessories and can start the car by shorting across the solenoid,and it will run fine.i put a voltage tester on my ignition+ wire and have 12 volt with the key in the on position,but if i turn to the start position and engage the starter i have no power to my ignition or accessories until the key is released and returns to the on position.please help. the only thing i can think of is the ignition switch is bad.
