cherokeechief79
my sons 67 wouldnt start the other day.no crank at all after sitting a while.
we looked at it the other nite in the rain and it cranked with a screwdriver at the solenoid.
he turned the key and i put a test lite at the yellow wire and it lit.
is there anything obvious at this point?
cant be a bad connection at the starter if it cranks with a scredriver.
it may have a bad connection at the connector on the yellow wire(i think its yellow).
if i take a wire directly from the battery and touch the terminal on the solenoid where the key wire goes to it should crank right?
