No switched 12v or cranking after eps install
champyfz450
Alberta
Hey folks, I was hoping someone might give me some pointers on what else to check on my 71 Demon. I have 12v going to the steering column but nothing comes out when I turn the key either “on” or “start”. I’m testing at the 8 pin connector on the column. The car is modified but the harness is practically as it was. The only wires I used from the factory harness essentially was the tan & light blue to provide switched power to my accessories (Holley ecu, digital dash, stereo, starter solenoid etc)
I guess what I’m asking is, is it possible that I messed up the key switch while I was in the column?
