Hideogumperjr
I got my drums converted to discs, got my new wheels and new tires installed and my front end aligned. New calipers and pads. New master cylinder from NAPA for a 74 Dodge Charger, info below.
I swapped out my 7 1/4 rearend with 9" drums with a 7 1/4 with 10" drums. New brakes and wheel cylinders etc on the rear end. The rear end has more backlash in the spider gears than my original rear. I pulled the drum on the rear and there does not seem to be any dragging coming from there. I have some suspicion that some noise may be from the rear end.
Problem is I am hearing roaring noises as I get up to 35 mph or so, I have not gotten too much faster than that. I cant tell if it is coming from the front or rear yet. It just gets louder the faster I get.
I know I read somewhere about the MC causing dragging on the discs if a valve was not pulled from the MC. Can someone enlighten me on this? Can anyone suggest what I can check out?
MC info
Part Number: NMC M2066
Brake Master Cylinder Bore Size : 1.03125"
Brake Master Cylinder Line Thread Size : 1/2"-20, 9/16"-20
w/ Manual Brakes
w/ Reservoir
Wow what a ride but nice to have it on the road again!
Thanks
John
MC info
w/ Manual Brakes
w/ Reservoir
Thanks
John
