Noob in the midst of a 65 Cuda Formula S resto
IceWarrior
Member
Germany
Lord help me, parts are few and far between for this ride! I'm going to get it done one way or another.
Any ideas where I can find new chrome trim? Trim the same on the Valiants and Cudas from 64-66 by chance?
Ice
Hello, welcome and good luck!Is it getting cold there already depending on where you are, north or south.
Thank you! I am southwest, still like high 60s and 70s here. Still have the month of October, then it really gets cold out here!
worked?
Welcome to the best spot on the web, glad to have you with us! This may be the best place to find that trim, and if I have something you need ill be glad to help out! Nice little project you have there!! Put a list together of your needs and well get to work on finding that trim!! Geof
Thanks for the warm welcome!
First order of business is converting the P/S to a new 16:1 manual steering box from the river of flames, also using their P/S to manual steering shaft adapter and new pitman arm from PST.
Laysons (member and sponsor) has a lot of stuff for early A.
Welcome to the site. I was fortunate enough to pick up a wrecked '64 Bcuda and used it for parts on my '65. Yes, the trim between a 64 and 65 are interchangeable. Valiants are not exactly the same.
Good luck in your quest!
