[SOLD] NOS Master Cylinder
Robert Dart
Burley, ID
NOS Master Cylinder. Box shows part # E64872 EE71258. Was told for manual Disc and drum?
$40.00 + shipping from 83318
Can you post a picture of the number cast into the underside of the master cylinder?
Can you give the number below E64872 that appears to end with 77.
For a manual disk/drum car the actuation rod going to the pedal is usually there and sticking out. I'd say for a power assisted disk/drum car. Measuring the center bore is also a telltale sign. Manual brake masters have a slightly larger center bore.
Most likely it was boxed wrong. Eis catalog shows E71258 fits 1967 thru 1970 drum brakes with manual or power brakes. Casting number 3580121 fits 1973 thru 1975 disc brake abodies. The Eis number should have both reservoirs being the same size. Your master cylinder has large and small reservoirs which indicates disc brakes.
