[SOLD] NOS single ballast resistors 2275590
halifaxhops
It's going to get stupid around here!
Hoppyworld, PA
I have six NOS single ballast resistors 2275590 These are the 0.6-0.5 ohms when hot. They are used on allot of points cars. Asking 18 shipped lower 48.
That must be Mopar's new and improved version of the earlier one with the same part number. The original early version has a metal mounting strap in the middle and uses a different mounting screw. It should work just the same, but, if you're looking for concourse correct appearance for the earlier models, it wouldn't be. I'm not sure what year the change was made....'67-68? '66 for sure uses the early metal strap version.
those are the 2095501. Sam ohm rating different style. These were as far as I can tell 68 and 69 definitely on the roadrunners. IPB will be the definite answer of what they used on that year/car.
