bobscuda67
I took my car out Tuesday and ran around a little bit and on the way home I ran it a little hard. When I got to the stop sign it was running rough and it had a lifter tic. So I babyed it home and took off the pass valve cover and sure enough it had a loose rocker. So I adjust it and start it, and it still has a loud tic and idling very rough. Is that the sign of a collasped lifter? I never had one before. If I take them out how can you tell if it's collasped?
It's a 340 with magnum heads and Comp Cams lifters, so it doesn't have shafts. The oil pressure is good too. Bob
