JeffTheMarine
Ok well here is the situation that I have. I know it is not an A Body but it is a Mopar question and a slant six also. I currently have a 225 /6 with a NP435 trans and an 11" clutch with the low position starter. I am going to be converting to an A833 OD trans and I have the bellhousing from the truck that had the OD trans and it has a high starter and a smaller clutch. Does anyone know if the NP435 bell will work with the OD trans so I dont have to switch my clutch and flywheel and everything.
Thanks for the help
Jeff
Thanks for the help
Jeff
