jimjimjimmy
lobsterman
Is it ok to use anti seize compound on the threads on an o2 sensor .
I can't recall if i have ever even seen one that came out of the box without antiseize on it.If memory serves, it's officially not okay, but the last one I put in had copper antiseize pre-installed on its threads.
I believe it's all about the possibility of contamination of the sensor by the metals in the antiseize. If you use very little and put it on the threads in such a way that none goes forward into the exhaust system, you'll be fine.
I've always put copper antiseize on mine – you'd never be able to get the darned things out otherwise.
– Ericc
