Offenhauser /6 4BBL 390 Holley
JeffTheMarine
Pacific Northwest
Rating - 0%
0   0   0
I am selling my setup for a slant 4bbl because I'm deciding to go a different route. It is an Offenhauser 4bbl. The vaccum port threads are great so are the carb mounting threads. Also comes with the correct Mr. Gasket adapter to mount a holley carb. It is set up to mount perpendicular right now. I am also throwing in a newly rebuilt 390CFM Holley carb. It has been rebuilt and is ready to mount on. Accelerator pump is still nice and pliable. It has not been sitting for long. I recently sandblasted the whole intake so it looks great and can either be polished or powder coated if you would like. I will get some pictures up a little later today. I accept PayPal or Money Order.
Thanks
Jeff
Asking $350
Located in Caldwell,ID outside of Boise 83607
.............ur adapter is to mount a spread bore carb........is that holley a spread bore or a square bore...........kim...........
390 's are square bore & should mount right on that manifold. list #8007 ,Lawrence
Yes, 390 Holley DP.
Holley adapter being held down in blue, yes square bore
It is a square.bore carb. Not a spread. The adapater was on the intake when i purchased it and i had not attempted to mount it yet. Either way the adapter comes with the intake. I'm open to offers.
Thanks
Jeff
Are you interested in selling the carb seperate?
If so how much shipped to Gloucester va 23061?
what would this setup require in way of linkage ? do you have any of it ? it would be for a 73 Dart Swinger 2-door hardtop coupe 225 /6
As fara linkage i don't have any. I can't imagine it riotous be too hard to make something. I had am offer on just the inquire so if you wanted the carb then i would probably take 160 shipped for it.
Thanks
Jeff
