Got an early A slant with the OEM rotating rod actuating the 1 barrel. Want to add a 4 barrel intake and modern carb? Here is an OEM Offy conversion package of linkage parts to convert from the OEM rotating rod package to operate the throttle assembly on a 4 barrel carb. This conversion package left the OEM pedal and bracket in the passenger compartment and part of the original rod in the engine compartment and added addition parts from the OEM rod to the carb to actuate the carb’s throttle. Apparently this kit is long been discontinued as I found nothing for it on Offy’s web site. I believe the kit is complete (but can’t verify it) other than the instructions which I do not have. $50 plus shipping from 22657
