duster731
young gun
Ok so I recently bought the aero rims from summit and I put both of them on in the rear and there suppose to be 4 in backspace but one side sticks out maybe a 1/2 more than the other with the tires on them so I took them off and made sure the rear end was in place and it was so I measured the wheels and it seems like One side is 1/4 off but this measurement isn't accurate to say thats the problem I put a piece of wood against the tires and measured from the outside of the rims center hole to the inside of the price of wood...
I'll have to measure it again when I find out the right way to measure... If this is the case do you think I can just add some thin metal spacers once I find out the accurate measurement if so where can I get these spacers for the large bolt pattern... Thanks guys
