It will come down to oil pressure.Also, would there be any problems using a 5-30W synthetic in the engine
Thanks, Dana!It will come down to oil pressure.
My 273 with 150,000+ miles on its 1st rebuild will flicker the oil light when hot ideling with 30, with 40 no light flickering
As for the 5W Vs 10W, you're in San Diego the average temp is what 75 with a low of 74 and a high of 76.
Here in Northern Colorado I can testify that 10W-30 is thick syrup at 20 degF
You would not have that issue where you are. But it won't hurt anything. To use 5W or 10W
The FSM calls for oil grade, check it out.
Free download at mymopar.com
Haven't dealt with an A100 before but I've had other trucks/vans with the/6 and these have always been 6 qts with filter.
Put 5 in, run it a minute, shut off and check with the dipstick. You'll either be OK or still 1qt low.
And as far as oil weight I wouldn't go below 10w30 or 10w40 but because of problems some experience with oil pump drive gear going bad (which is driven off of the camshaft and the cam gear eats itself as well when this happens) I wouldn't go any heavier either.
15w40 is also not needed. I definitely wouldn't run straight weight either.
10w30 or 10w40 would be my go to.
Thanks for the advice.5 quarts with filter change. Not sure on the oil...I'd stick with 10W30 or 10W40, but that's my opinion.
