How soon after breaking in the 512 stroker do you change oil? ASAP, 1 hour, 5 hours? What oil weight, brand, type is recommended. The motor has a moderate Flat tappet cam, High volume oil pump that is giving 75 psi at 1500 rpms.
We are removing the transmission to see where our leak is tonight. I used Fluorescent dye and it is either the rear main or at the rear pan gasket. I would like to keep the Dye/oil in until we get the leak fixed and then change the oil. The motor is on a run stand and will not go into a car without an oil change
