I need to install a 90 degree oil filter adapter on a small block 273. The one I have is cast iron. Obviously, the large paper gasket and the small thick cork gasket from the rebuild gasket set go between the adapter and the block. What goes between the bolt head and the adapter? It seems that a gasket would be destroyed when tightening the bolt.
