Mine looks exactly like that one I am using the dual filters, I like mine alot wouldn't do it any other way, burned my arms too many times with headers and the 90 degree filter adapter.
Ya Thats my thinkin to, that and putting 2 large filters will give me for sure 2 quarts more of oil so i can stick with my old 5 quart oil pan nd still have a 7 quart system with better filtration and cooling....i no i saw one with longer hoses but were connected by gear clamps nd i dont like that idea it was like perma somethin
If I may suggest, only my opinion, that if you are going to run two filters get two single filter mounts, and run them in series. This allows you to use a good quality filter first, then an ultra filter second and not sacrifice flow to get the finer stuff out of the oil.
The double mount runs them in parallel.
Andrew
