oil filter
moparraceman
mansfield ohio
what is the real small oil filter used on a body, when running headers ,and not using 90 degree oil filter adapter ? thanks
One of many, NAPA Gold FIL-1348
K&N BK HP 1002
Baldwin BT223
Probably the Wix 51068 or 51085, Fram PH16.
An even smaller one would be Wix 51348, Fram PH3614.
Stay with the biggest filter that will fit, however. The smaller the filter, the less flow you generally get. The flow rates are on the manufacturer's websites for comparison purposes.
