Oil or ARP assembly lube on factory bolts?
dibbons
La Paz, B.C.S., Mexico
Would you recommend using the ARP fastener assembly lube on factory main cap bolts or would that cause them to be over-torqued? Same answer for factory head bolts? Thank you.
oil on the threads and under the bolt heads. torque on the heads 100 on the short bolts and 105 on the longs. and 85-90 on mains
