Vali68
i have a slant 6 on an engine stand and i am now putting it back together. I applied the oil pan to the block, but from looking at the back side of the block to pan, I can see the bolts that hold the rear seal cap in place. Is this coorect? It that all the seal that is needed? The rubber seals are in place on both the rear and the front along with the cork gaskets that run down the sides of the block and oil pan.
Also, I have seen 2 different torque limits on the oil pan bolts. one says 100inch pounds and the other shows 200inch pounds. Which is correct?
