Are you trying and just can't get it to come out?? Usually unbolting the Motor Mounts and a little lifting etc...will do the trick. I did it with a 66 318 dart.
i can imagine if you get the centerlink and exhaust out of the way (if its a single) and if you can get to all the bolts, you may be able to finagle it around the pick-up .....do i dare ask you why you would need to?
