Holy Roller
Has anyone tapped out the 3/8 inlet for the oil pick up tube to 1/2 on a 383 when using Milodon pan, pick up tube, windage tray and hi volume oil pump?
Thank you
Thank you
Kim, did you do it yourself or bring your block to the machine shop.Yup. Kim
I think that's a good idea in my case, the machine shop probably has better tools to do the work with anyway. I think I want to have the work done to stroke it too, just in case I choose to go in that direction. Which windage tray did you use? I'm using a milodon pan and the 1/2 in inlet pickup. But kinda confused about which tray to use.Both ways. I did mine many years ago. U have to be pretty careful. Then on the oil pump side it’s nice to smooth out the corners, but it is a little difficult. Drilling the main bores bigger helps a lot. Have to have a good bit for that. If u brake the bit off the block is basically junk. Do any drilling and bringing on the block b4 u get any machine work done. I just let the machine shop do it now. Kim
