oil pressure hike
mygasser
faversham, kent. united kingdom
just a quickie here. has anyone increased their oil pressure by just pressing the plug in further onto the pressure relief spring then adding a washer or two before refitting the split pin? if so one washer or two and what if any pressure increase did you achieve?
cheers, neil.
cheers, neil.
Yes. As long as the spring doesn’t go into coil bind you’re golden.
