Oil pump drive ???
Newbomb Turk
In The Clouds
Has anyone ever encountered an oil pump drive that would not go in?
And then it was wedged in so tight you can’t get it out?
If so, what was the fix?
I have a brand new drive. I have no idea when I got it or where. It’s a nice piece with the pinned gear.
I drop it in the other day and it just sounded weird. So I looked down in there and it’s about half way into the cam gear.
I grab my long screw driver and try and turn it so it drops in. It won’t move. Either way.
So I grab my trusty wire hoop I made to get under it and pull it out. That didn’t work.
I was going to pull the tunnel ram off and pry it out and then I decided that was stupid because whatever is jacked up can’t be fixed sitting on the dyno. So I take that steaming pile of whale turd back off the pump.
I get the pan off (royal PITA) and I loosen the pump. It won’t fall out. So I take the bolts out and wiggle the pump. Still stuck. So I lift the pump up about .125 and the drive falls out.
WTF?
So I put the drive in the lathe and get a dial indicator on it.
It’s bent .034! My chuck has .002 run out and it measured .036. I call that junk.
I have an ok used one on the shelf. I ckeck that junker. It’s .023 out. Straight garbage.
I decided to get it back as straight as I can. I worked it for a bit and got it down to .005 runout.
The pump is back on and the drive will unscrew right up out of there like normal.
I guess from now on I will check every drive before installation.
Just an FYI.
WTF?
Just an FYI.
Yeah, in this day and chinkesium age, you best be checkin everything.
Yup. It’s costing me two days to get it back off the dyno, on the stand, unscrewed and now I have to get the pan sealed back up (royal PITA) so I can get it back on the pump so I can install the distributor and see if this way over budget garbage will even start.
If I was paying myself for this job I’d be broke.
Well thankfully, it's somebody else's money. lol
It's not a big block one is it ?
Lol, asking for a friend.
How did you bend that damn thing . That sucks
Atleast it will be right when it's done dude.
You're 2 minutes late to Crimis eve by the way.
Until recently, Camshaft install/ fit usually went well. BENT ****, fresh out of the box, has now become a ' Must check' procedure. Oil drive shafts are probably the next thing 'WE' can't ASSume are good-to-go out of the box.
Some of the small blocks have a step in the shaft and some
are straight all the way down. With the bushings that are now
available I have to use the stepped ones.
I do not know if you are working with a small block as that is what
the majority of my builds are.
If it is a big block I would in a pinch consider either remove and hone the bushing
or machine down the drive as a quick fix.
