oil relocation kit
dart67
NH
I need to move my filter and need longer hoses,can I use heater hoses?
Thanks
heater hoses will not handle the heat ,i bought hoses from jegs but if u can find them at other speedshops or hydraulic hose shop
regular heater hoses will get soft and fail if you were to run oil thru them.
I used a canton racing adapter, braided lines, and a ford type remote mount.
There are many companies that make the mounts.
Here is the swivel part from canton on the block. You can adjust the poistion, there is a plate that goes behind it too. Both parts flow better than the factory adapters too.
It used a standard full spin on mopar / ford type filter. Pic show was a test fit with a crappy fram filter for testing only.
tel.203.481.9460
http://www.cantonracingproducts.com/index.html
#22-610 40.00 Accepts Ford Type Spin-on Filters.
#22-575 40.00 CNC machined billet aluminum filter
#22-595 70.00 Ford, Mopar, and applications with 3/4-16 Thread & a 2-5/8" standard seal.
You also need the 2 sided threaded stop nut to hold th eplate on. Canton carries it, and I think you can get it from Dodge too?
NOTE:
Moroso is a 1/2 pipe compared to 3/4 size of canton parts
