71swing
Well hope somebody can answer my question.
I had an oil leak on the front of the intake, so I'm in the process of removing the intake and fixing the leak.
I now have the intake off. But have a slight concern. In the picture below you see a lifter valley cover/ pushrod guide plate. It has been about 5 years since I put this together with my father and can not remember for the life of me what is on the bottom of the plate securing the bolts on?
I understand that the cover is being held in place by the heads being bolted down but my concern is the bolt that is connecting the flex straps to the cover.
I would hope that a mopar design would not include a bolt and nut combo on the inside of an engine. Is it something that I should be concerned with maybe coming loose and destroying my motor? I don’t need a nut falling right on the cam as I pulling 6000 rpms down the track.
What is on the other side of the plate attached to the bolts?
I hope somebody can answer I don't really want to pull the push rods out just to take of the cover to findout it was not a reason for concern.
