since my breather is basicaly a pcv
This IS NOT the case. A breather is just that, a breather.
I was wondering about this Diagram even before you posted it up. Is the system directional??? I know that sounds stupid but it would make the PCV valve belong on the Passenger side instead of the drivers side etc....Just wondering..:glasses7:Here's a diagram of how the system works
LOL, Now that's some funny S%$%49 posts and still?
In the before you can see the PCV valve in the passenger side valve cover (or at least it looks like one). In the after it has been eliminated. THIS is the problem as I have said repeatedly. If you would listen, after all YOU ASKED for help and you have gotten it, you would be on the path to correcting the problem.
Knock out the plug in the passenger side cover, get a grommet and put your breather on that side. Get the right size grommet and put the PCV valve on the driver side hooked to full manifold vacuum.
PROBLEM SOLVED!!!!!!!!
By the way I would suggest you replace that plastic gas filter for a metal one, but that could be another 49 posts.
i was going to touch on that but that could get too deep for this conversation lol. maybe the rings are totally shot and no breather or pcv would help this situation lolone breather is fine, ur rings r crap if blowin the dip stick out.
pcv is optional. imo
Ive run w/o a pcv and just a breather,,,never shot the dip stick out.
What carb are you running?
if it has a bowl vent..u can route one of the breather hoses to it, or better yet...'the air cleaner'.
The thing is that it was fine before he swapped out the Valve covers.i was going to touch on that but that could get too deep for this conversation lol. maybe the rings are totally shot and no breather or pcv would help this situation lol
We can only hope so...I would think the breather would be letting out the pressure even if it is not the correct system. You gotta start with the little stuff first though. Wonder how it's going????:clock:yea,i read that one page one. i was being sarcastic. im sure his rings are fine, otherwise he would have had blowby before the switch.
i did go get a pcv and changed it but with the breather it took awhile for it to start making the mess it did i cleaned that all up so im going to drive it for a little while and see what happens. the carb is a 2bbl holley i dont know what size it is for all i know it could be a 400cfm but who knows
are you talking about the valve cover gaskets? or the new grommet? if you mean the VC gaskets, the best ones out there are the felpro rubber gaskets for aluminum covers IMO.drove it for like 30 miles got home looked at it and its covered in oil doesnt look like its coming from the dipstick tube but i didnt have the car on when i looked now it could possibly leaking from the gasket since autozone didnt give me the material i wanted cause they are stupid and didnt know what i was talking about
No pvc / pressure in the crank case
where the breather was is now a pcv and oil fill caps on both sides
