Ok now what is my car worth?
taco502001
I posted earlier to confirm my belief that my car is a demon in fact and not a dart as the appraiser keeps on saying it is or could be. But in fact I and many others know its a demon.
1971 Dodge Demon Curious Yellow
46900 original miles
Top half is original paint bottom half of car was repainted no rot extremely solid underbody, paint on a scale of 1-10 10 being best a 7-8
Interior is all original in extremely good condition
440 6 pack shortblock that has been rebuilt
Few Things The Car Includes
AAR Fiberglass six pack hood (Flat Black)
Original Curious Yellow Hood
Weld Chrome Wheels with 4 1/2 bolt circle
Race Demon 825 cf gc carb
Wieand G Force Aluminum Intake
K&N Air Filter with extreme top
Mallory Electronic Distributor 8mm copper wires
Drive Shaft loop
Frame Ties
TCI Line Lock with Chrome B&M shifter button
Milodon Deep Oil Pan
Hooker Super Fender Wall Headers
8 3/4 Rearend with Mosher axels
B&M 3000 Stall Converter
Auto Meter shift light and Tach
Auto Gauge temp, oil and electric gauges
Forged Steel Crank and Rods
Front Disc Brakes
Flow Master Mufflers
3 1/2" exhaust to Chrome tips
Rear tail stripe still in box to be placed on car
9.7 to 1 compression
Runs great on pump gas
292/502 Comp Cam and kit
Aluminum Water pump and hosing
Braided steel fuel lines with connections
March Pulleys
906 Heads with harden seats
3-angle valve job with bronze guides
Perfect circle seals
Comp cams double spring retainers and keepers (valve locks)
Completely balanced bottom end
Special 5/16" T-6061 Pro Engine Mounts (Elephant Ears)
3-core radiator
Hayden Super Heavy Duty Trans cover Large U-joint drive Shaft
Super Stock springs 1.140
Grant Leather Steering Wheel
If car was repainted, bumpers rechromed and a few dressup things done this would be a completely restored show car
NASCAR Torsion bars
The value of your car depends on how you are attempting to value it.
Stock:
If the car left the factory with the 340 as stated by the numbers, it will have a higher value than a non-340 version. Production numbers will usually favour the model with the lower production numbers if engine displacement is same.
Modified:
If the car is modified, then you cant ususally use this as a "set in stone" guide. Instead, you should have your car appraised by a professional. They will take in to consideration the condition of the vehicle, the costs of modifications, and execution of the modifications to come up with a value.
SInce your car is a beautiful modified, the value could easily exceed what you have stated in your other post. A lender does not have the expertise to do this, instead looking up simple numbers based on VINs. IMO, get it appraised.
Grant
I have one appraisal done for 16,500 who expertises in this area called the bank they said it had to be done by this tw lane. He appraised it at 10000 but that was based off a dart not a demon and he really thought it was a dart not a demon and its a freaking demon I used the decoder here and seen the difference in body styles btwn the two. I have another who has seen photos and list of what is done and seen other comprable cars and he says 15000 and another who says the same so 3 out of 4 appraisers say its a demon classic/modified worth 15k or more than I have this one who didn't even or couldn't even tell it was a reall demon and not a dodge dart.
Stock:
Modified:
Grant
I agree, after seing the pictures of your car that it would be easily valued at $15k. I'm not saying that if you were to try and sell it you would get that, just that the condition of the car would warrant that price. It sounds like you need to talk to the guy that appraised your car at $10k and convince him otherwise. If I remember, you were getting an equity loan on the car. Maybe it's a sign that this isn;t a good idea. The appraiser is probably playing it safe with that value that you feel is low.
