Old flexplate doesn't want to come off
MrJLR
Built, not bought
Menifee, California
All the bolts are out...no pins I can see. ..
That sucker doesn't want to come off. ....
Is there a trick I don't know?
Jeff
Lol...it's off....I had to beat it like a red headed stepchild!
Thanks....thought I'd ask first before busting out the BMFH....
JEFF
hopefully it didn't bend or crack if you plan to re-use it. But I have seen those take a royal beating and still be ok. But you might inspect it real close, if you didn't already.
Lol...I bent the snot out of it!
I should add I'm replacing it...new one is already locktite on...
Worst that can happen is you damage the crank or Damage the thrust bearing.... 98% of the time it will be just fine.... March on Jeff.... Vroooooomm Vrooooooomm
