64drtGt
Slant Six Lunatic
I have one last cam question. I had originally wanted to run a whiplash cam but decided it was out of my budget and decided on having my cam reground. Which of these specs would you guys recommend?
My engine is a stock magnum with headers, holley carb, 4 speed, and for the time being 3.23 gears but I am going to swap out my 4.10 set later. Its going in a truck but it wont be using for any series towing or work. I just want it to run pretty good around town and sound great doing it.
This was the info I got from them so far.
1458
206/212 @ .050", 258/264 adv, .480"/.488' lift(1.5:1 rocker)
#1429
210/214 @ .050", 260/264 adv, .474"/.474" lift
#1161
210/215 @ .050", 266/270 adv, .498"/.498" lift
These profiles are as close as I can come to the whiplash specs. I can put these on the 107 lobe sep if that is what you really want. If you are using a computer engine they will probably not work with the 107 sep. Most of the factory cams have a 114 to 115 sep. It will be difficult to change the sep to 107 using one of these cores with out making the lobe diameter pretty small. There are a couple that have 110 sep which could be changed. Also the original roller cams are made from cast steel which is not very durable. If you have a cam core that we can change the cost is $117. We can make a new one for $325.
Thanks
1458
#1429
#1161
Thanks
