I have one pair of these. They are from a 1985 Fifth Avenue. These are slightly thinner and lighter than the 1973-76 A body units but will bolt in the same way.
These will fit ANY A body as long as the larger upper ball joint is used OR the spacers/adapters from Dr Diff that allow the use of small ball joint upper control arms.
The caliper adapters allow use of a 11" rotor and slider calipers. There are options to run 12" Cordoba rotors using the larger caliper adapter brackets found elsewhere.
$200 shipped within the USA. These barely fit in a USPS flat rate box.
No ball joints, no calipers. What is included is the left and right spindles, the 11" rotor style slider caliper brackets and the mounting bolts.
These have been cleaned but will need some more scrubbing for show level beauty.
I ship from Northern California and prefer PayPal for payment.
Thank you, Greg
Thank you, Greg
