dodgetkboy78
EDELBROCK HEADS SUCK!
OK, so, now that I have had to build a total different backwards turning 360 for my boat... (long rant, wanna hear it?) CORRECTLY, I am using the adjustable rockers that came on it. The cam is used, and the lifters are used, cam is mild, less than 400 lift, stock springs. NORMALLY, I like to go a 1/2 turn past the plunger being extended, but this is in a boat, and you have to pull the exhaust manifolds off the get the valve covers off, in a hole.... SOoooooooosoooooooooooooo
I never want to adjust them again, what would you guys run them at?
Pop quiz, what happens when you run a block with the back main 60thou south of the rest??? (like, .060 out of line) Yes virginia, with standard bearings on a .020 crank, I guess it IS possible....)
