SRT_DSTRHOLC
Im ordering PPG 2021, but I need a little help with the quantities. How much reducer and what type should I purchase? Warm or MED? And How much Hardener? Thank you.
I found this about the reducers
"DT885 can be used from 70 degrees - 85 degrees DT870 is used for 65 degrees to 75 Degrees and DT895 is for 85 degrees to 95 degrees and DT898 is for 95 degrees and above" And I read that some say to get the slowest reducer, does that mean the DT885 would be slower?
