I have a new Oregon Cams small block hydraulic roller cam part # 1634. This cam has the long snout for use with mechanical fuel pumps and will work in both LA and Magnum blocks.
Specs with 1.5 ratio rocker arms are:
Lift 492 intake and 501 exhaust. Duration at 0.050 is 218 degrees intake and 224 degrees exhaust. Full specs are in the pictures. This cam uses the conventional iron oil pump drive. Cam is sprayed with oil which gives it the blotchy look.
Price is $230 shipped in the lower 48 states. I will ship internationally for the extra cost.
